Posted 2/26/2012 22:30 (#2254086 - in reply to #2250654) Subject: Re: Calmer BT Chopper Knife rolls
SE ND
Thanks so much for the info, very helpful. What type of disk ripper are you using? No plugging trouble with your rig? We typically do tillage right after combining...sometimes the same day. Can you run the corn head fairly close to the ground and do a good job of creating a fairly clean cut and short stubble? We would be running around 4.5 mph as well.
