| PER:
Thanks for the help. I do have a utility program that came with the PF 3000. I have it on a TR99 new holland and the program is from New Holland. It looks like it will do mapping and save other information. The unit is not on the combine yet they had the wrong moisture and yield sensors with the monitor. It looks like you can hook the monitor up to the computer to download information to. When do you use the load function in your field. Do you set this up when you are in the field and combining. It looks like a tare feature like on our grain cart scale, wo you can look at different hybrids to see how they are yielding compared to each other. Any other tips you can give will be appreciated, the mechanics at the shop are busy this time of year and I have to see how some of this is set up rather than read it from a manual. I do have my fields entered into the monitor and will proceed after the guys get the sensors mounted on combine. I did not know what a GPS system costs, I know the price is coming down. This is a used system so I did not know what it would be worth. I have not had time to research this item. We just got the combine and the yield monitor was in the combine when it was new, but the farmer did not want it, so the dealer through it in on the deal we made. I suppose it is really obsolete. I can at least begin to learn with this system without too much money invested. The GPS portion the dealer had to buy from a other electronics guy and that is what he charged him.
Thanks again
Rod | |
