Search Forums | Classifieds (139) | Skins | Language
Titan RT
Applicator
Posted 9/3/2007 22:16 (#197878 - in reply to #197839)
Subject: Re: Titan RT
The screen update problem is aggravating, but not fatal. You have to turn the as applied map off when it gets too large to be completed before the controller expects a rate command. If you don't a loss of communication alarm goes off, and a skip in the map appears. This gets worse as the map gets bigger. The actual effect is that the rate command is delayed until the on screen map is completed. I have a 400 MHZ Dell (same speed as the Titian), and Farmworks said (about a year ago) that the same thing happens to other brands. My limited knowledge of CE devices leads me to believe that the CPU also runs the screen. A question on Farmworks Sitemate discussion group might be in order to see if I am wrong or if this has been fixed.
As for Raven Autosteer, I have had good performance. Poor performance with the Raven Invicta GPS receivers.
