Posted 8/31/2007 14:22 (#196306 - in reply to #196291) Subject: Re: Need some numbers for 500 guide and steer
Sunnyvale, CA
use the tune up wizard starting from the default values for the type of vehicle you have it mounted on. It should only take a few minutes with the wizard to dial in good performance. also make sure you have the latest released code 2.00.043 in the EZ-Guide 500.
