Edgeley, Saskatchewan | Hi all,
I am haveing trouble with my 1066 losing steering when started after a long time off or when cold.
I was told to add 5 gal of Hyd oil above the "full mark" as it covers an O ring that avoids losing prime. We did that and seem to work. Now the problem is, it has been a while and when you loose a bit of hyd oil here and there, where on the still should the new "full be? Does it hurt to have too much hyd oil in the rear end?
Thanks | |
