Posted 5/22/2006 18:29 (#14041 - in reply to #14019) Subject: Re: liming/pH help needed
Martinsville, Ohio
If you are putting down potash etc I sure would add 200 lbs of pel lime. Otherwise I also would forget it and look at an inoculant with something added like Molybdenum. Moly Soy Alive is a good product in your situation unless you are using a planter with sensor that are easily messed up. A drill will handle Moly and humus inoculant.
