Posted 5/20/2006 22:33 (#13626 - in reply to #13572) Subject: RE: old 2,4-D....any good?
Lapel, In
Take a stick and push it down to the botton of the can and twist the stick a bit.If it has salted out,you will feel and hear the crystals being ground by the stick.And if it has salted out,put the container in the bed of your pickup and haul it around for a few days.The agitation plus the heat from the sun will dissolve the salt and the chemical will be as good as new.
