Near Intersection of I-35 & I-90 Southern Mn. | Apparently you are not using the current version of firmware for the EZ-Guide+. The newer versions allow the operator to set the whole number portion and the decimal portion separately.
Older versions required running the heading up or down in .01 steps as you describe.
The firmware upgrade is free and available via Trimble, Ag Leader or other sources. Your dealer should be able to help you with the upgrade. |
