| I Have Two Challenger 665C Tractors On RTK Base Stations. One Of Them Has The Steer By Wire CAN Steering And The Other One Has A Full Install With AgLeader/Autofarm Compact Valve And WAS. I am Having The Issue Where Both Tractors Will Steer Fine For 300-400 Acres And Then Will Jump Off Line 8" And Come Back, But At 13MPH That Is Alot Of Crop That Gets Run Down. I've Changed Out Base Station And Also Changed TO The AgLeader Block, They Were Both CAN Steer By Wire At One Point. Any Suggestions | |
