E Manitoba | alange
you make a valid point, the earlier firmware was so far out that I lost faith in the lightbar and reverted to my old method of using foam and following a row down the field,as our fields are flat and square this works well, the sprayer is a pull type 110ft wheel boom so it's easy to get a slight overlap,i found yesterday that the lightbar tried to pull me into an even greater overlap.When it dries up I will try driving to the light bar and get off and check the accuracy. | |
