E Manitoba | If you are using EZ steer there are compatibility issues, read release notes first.
Use the cable provided with the EZ guide + to hook up the lightbar to the computer.You will also need a 12v supply for lightbar.Download and install EZ-Toolbox (v2.10) on computer from www.EZ-Guide.com Download firmware version4.10 from same source ,EZ toolbox should open the file and give instuctions. Test it out before going to the field the older download ruined what was a good system so I downloaded this newer version yesterday, haven't tested it yet, fields too wet, no signal in yard. | |
