central iowa | It is because of the PWM hydraulic valve that runs the spray pump which ez boom does not support, you must go Insight and direct command. I have wanted to try to hook one up anyway with the adapter cable that allows you to keep the 460 in the cab and only use the ez boom for auto boom shutoff only, which still wont be supported by trimble/ag leader, but if you tell them it is in a pull sprayer you could get some support. Has anyone tried this and if so how did it work. I have one in someones hands who was going to try, but they haven't got it hooked up yet.
kirk
