roaming | From the GS receiver, you'll need a cable that ends in a 9-pin serial connector. Your JD dealer should be able to find this cable for you. Then use adapter 87302445 (from your CaseIH dealer) to convert the 9-pin to a flat 5-pin connector that will plug into your combine. I don't know whether GS receivers require a null modem (crossover) cable or not. To the best of my knowledge, they don't, but I wouldn't put too much money on it. Your JD dealer should be able to tell you for sure. | |
