NE SD | Field doc records where the reciever is until you put an offset in. If you go into Setup > Field Doc > Operation > Implement there should be some implement offset options under there. You can adjust for lateral offset in case your implement trails slightly off to one side like our planter seems to and then there is an inline offset for where the implement is in relation forward and back to the reciever. | |
