Remsen, IA | This cable will feed the speed to the tractor and then you plug the Raven into the tractor radar feed.
Harness - StarFire iTC Radar Adapter
NMEA information is available through StarFire iTC SF1 World Solution or StarFire iTC SF2 Ready receivers when connected to a GreenStar System or with a valid SF2 license or RTK activation when used with a non-Deere system.
Tractors ordered without radar options require adapter harness RE52645. See Parts. Additional parts may be required for 6000 Series Tractors. Not Required for 8030 series tractors. 9020 Wheel Tractors (PIN 040001 and above), or 9020 Track Tractors (PIN 906001 and above). See Agricultural Sales Manual. PF90350 $130.00 | |
