Search Forums | Classifieds (1) | Skins | Language
Returning to an old AB line for AutoPilot
tedbear
Posted 5/12/2006 07:24 (#11607 - in reply to #11602)
Subject: RE: Returning to an old AB line for AutoPilot
Thanks for the replies - I believe I am hearing what I wanted to hear.
Yes I have the full blown Trimble Autopilot system which is tied into the tractor hydraulics. Since my 8120 did not come with the AutoTrac valve from Deere, it was necessary to use Trimble's (Parker actually) valve.
I only have a couple of cases where the Soybeans will be planted right next to corn field planted with the Autopilot. In one case it is actually the same "field" so the AB line that I have saved should work fine.
In another case the soybeans will be in a "new field" which is adjacent to a corn field with a different name. I'm thinking that I should be able to export the AB line from the corn field to the memory card and then reimport it back into the soybean field. This should be rather simple if it works. I'll have to try it but it would seem like the AB line will actually be outside the field boundary on the Insight display. Will this cause any problems?
