| Yes there is. Jumper with a paper clip on the harness side of the flow meter connection the ground and signal wire, black and white/green (not too sure on colors but a voltmeter/testlight will identify the power and ground. when you jumper the wires do it like your making pulses in/out in/out a bunch of times then go check your display to see if it counted any gallons. if it does then you have a either a bad flow meter or connection. | |
