Does anyone know if you can change the baud rate on an in incoming GPS signal on the CaseIH Monitor? I'm trying to send GPS from an EZGuide 500 with RTK, but the EzGuide 500 only allows 38400 baud with RTK attached. It appears I may not be able to output GPS while using RTK.
