Posted 4/12/2007 12:08 (#135273 - in reply to #135270) Subject: Re: EZ Guide 500 pin out?
Sunnyvale, CA
I forgot to add, if you get the cable 52033 you will get easy access to the external switch inputs through a weather pack connector. on the 52033 cable the coverage logging switch (or relay contacts) is used between pins B and C. The radar output signal on this connector is between pins A and B.
