Fargo, ND | If the optics are clean, it will be an internal problem. I am not sure of the 945 is a tube laser. if it is, you have either a bad power supply or plasma tube. A laser service center can check the mW output of the beam. That will indicate the plasma tube brightness. Set the laser up in a dark room and turn it on. if you see a straight red line the power supply is ok, if you see dots and dashes, it is failing. Either way it likely means a trip to a laser service center. Good Luck | |
