Sunnyvale, CA | we have discovered that some EZ-Steer controllers with a good connection can have lower bridge faults caused by a too sensitive circuit which results in a false triggering of the internal safety shutdown circuitry. The cure for this is to change some resistors in the EZ-Steer controller which de-sensitizes the lower bridge fault detection circuitry. AgExpress can do this change. When they make this change, they also change a capacitor in the Gyro power supply that causes the T2 Fault error at power up that sometimes appears. | |
