Near Intersection of I-35 & I-90 Southern Mn. | For the planter monitor you want simulated radar speed not wheel speed. If the tractor does not have a radar gun or has failed (very common) you should be able to get a cable from Deere to pipe the simulated radar speed into the tractor dash etc.
Then you can use the metri-pak connector behind the fuse door to connect to the planter monitor in the same fashion as would have been done with a true radar gun.
Edited by tedbear 4/11/2007 07:29
