Near Intersection of I-35 & I-90 Southern Mn. | John - I did the bench testing this morning that relates to your situation with an "unbalanced split".
It appears to work as hoped with your setup. This would require that you create a new implement (planter) that is setup in the 12/6 row split from the beginning. Once the planter has been setup into two sections you have the ability to change the split from 9/9 to 12/6.
The rest of the configuration would be similiar to what you have been using.
The color bands on the planting map will be 2/3 one color and 1/3 the other color. Don't forget to change the Auxiliary input switch settings so that your Master setup (imp switch and inline switch) go to E2 so that they once again control both the seed logging and that other product.
Edited by tedbear 4/9/2007 09:12
