Search Forums | Classifieds (1) | Skins | Language
Field Doc Connect
mws
Posted 5/5/2006 23:13 (#10219)
Subject: Field Doc Connect
DeForest, WI
We are currently trying to use field Doc connect to read from a Rawson
Accu-Plant controller. Field Doc reads the seeds/acre correctly thru the Rawson, but will not turn on the recording when the Rawson turns the planter drive on.
We have been thru all the settings on both field Doc connect and the Accu-Plant with their respective techs. No one can seem to figure out why the field Doc recording will not turn on.
Everything else on the Rawson controller works properly... ( turns on and off with the whisker switch and changes rates fine). Field Doc reads the seeding rate. There is no implement switch option with FDC because it is suppose to come from the controller. the communication status is active.
We are using the Original Greenstar ( my GS2 still is in the case)
We also just finished using FDC and a Accu-Rate on a separate Rawson controller for corn planting and that worked just fine!
We have used FDC with numerous Raven controllers in the past and had no problems.
AMS support tells me they don't know what to do and to go thru my dealer.
Just what I wanted to hear.
( We are not reading from a prescription - just trying make as applied maps and info.)
