South central, Nebraska | Trying to educate myself as to what you can actually do with these controls. The literature reads like you can use the two items together as a stand alone 2 rate sprayer controller. The EZ Boom has the rate 1 and 2 switch but where is the display for rates? I could not see anything in the EZ Guide information explaining this.
........update: I did find how to set EZ Guide as a controller........ Is anyone doing this now???
What if anything do you give up by not keeping a sprayer controller wired in?
If these controls are capable to run as stand alone, will they work with Hiniker flow meters and flow valves?
When will the EZ Guide 500 will be able to work with the EZ Boom?
Thanks
Edited by cbSCNE 4/6/2007 15:28
