Burgessville, Ontario | At least two, no three, or more ways to solve this
Plan A - Go to a known pass in the field and make an A+ heading AB line using the heading you used when planting. This heading will be the compass heading to four decimal points which allows you to duplicate your heading. Set your track spacing to 90ft. Now you will have two saved AB lines, one for planting and one for spraying. Make sure you name the lines correctly so you can recall them at a later time.
Plan B - Go to a known pass in the field and change your tracking width and overwrite previous AB line.
Plan C - Manually drive first pass for spraying using curved track and motor on after that!
THere are more ways, but it does get a bit complicated. I am sure other people will have ideas.
Thanks
Paul VDB
