Pittsburg, Kansas | You probaly want to add another Deere switch rather than try to use the one you have for two purposes. They are not that expensive and you eliminate the possibility of screwing something up in either or both systems if they dont play nice together using the common switch. You might end up back feeding voltage somewhere you really don't want it to be. If you are satisfied your knowlege of electronics are such that it will not be a problem, use the one switch for both - it could work. If you are like most of us, for 20 bucks why take a chance on frying a multi thousand dollar system or even just creating unwarranted problems to try and figure out - buy another switch.
John |
