Southeast ND | I was thinking about using the multiproduct unlock to record gallons/acre with a raven and also log split planter varieties by site verification. Is it possible to turn on and off the variety logging with the on and off for the raven that is coming in on the serial cable? If not, will a implement switch control the varieties without interfering with the serial connection on the module? Both connections would hook into the same app rate module. Also instead of a implement switch, there are times when I would like to be able to turn on and off logging with a type of toggle switch in the cab. Is this possible and what would be necessary to accomplish this?
Thanks,
Marty. | |
