| I'm trying to run Insight spray command on a Hagie STS 10. The first day I had it working fine, sections turning on and off as they should. A week later, all I can get is a spike in pressure on the boom pressure gauge. When I hit the master boom switch, there is no rate reading on the Insight, no total gal reading, no flow through the nozzles, but I do have mph readings. What have I forgottgen to enter correctly or turn on. Thanks for the help. Tom | |
