| If you are happy with the TeeJet I would stick to the TeeJet Products. I would take a look at upgrading from the Smart Pad to a L6K with Field Pilot. Your current GPS and Lightbar will work. The Light Bar needs to be sent in to upgraded to CAN. The only down fall would be the moving it back and forth, The L6K running in EXT- mode with field pilot is much like other systems that require you to purchase a install kit for each vehicle you want to use it on.
Please feel free to e-mail me if you have any other questions.
Thanks
Travis
