Posted 3/9/2007 17:09 (#117316 - in reply to #117284) Subject: RE: Implement work switch wiring on 9420?
Check at the implement connector, I think there will be a weatherpak two pin connector right behind the circular connector, probably tucked inside the harness shroud. This should be the wires for the implement connector.
