Near Intersection of I-35 & I-90 Southern Mn. | It's been a while, but I thought the Original Greenstar harness had a four pole AMP connector on it. I was under the impression that a Dickey John Radar Gun would just plug right in. Maybe the cable I am thinking of was only used with a planter population setup.
If your Dickey John Radar is a standalone model it should have an AMP four pole connector on it. If the Dickey John Radar gun came off an OEM tractor setup such as I-H (four pole square) or Ford (special Ford Round), then an adapter would be needed or the non standard connector could be cut off and replaced with the AMP style.
If the I-H or Ford adapter is needed, I have them available. Contact me at L&D Ag, 507-845-2100.
Edited by tedbear 3/6/2007 07:21
