Posted 2/15/2007 08:27 (#105259 - in reply to #104809) Subject: Re: 9610
MN
You also need to see if your moisture sensor is dual can compatible. The original YM system installed on 9610s were a 4/5 volt can system. The new JD receivers and ATU units operate on a 2.5 volt can system only. So you need the greenstar system in your combine to be converted to a 2.5 volt system if it is not already done.
