Use the flow control to set the spinner speed - then if you change tractors don't have to readjust spinner speed from tractor to tractor - just make sure flow control on tractor is high enough to meet the spreader mounted flow control requirements. Or put a speed sensor on the shaft so it is easy to adjust the tractor hydraulics to the right speed.
