Search Forums | Classifieds (109) | Skins | Language
JD Ops Center Bug
FarmWeather
Posted 7/19/2026 18:16 (#11704708 - in reply to #11704345)
Subject: RE: JD Ops Center Bug
Delta
KevinSeidl - 7/19/2026 07:39
This is working correctly, but perhaps not intuitively. The list of varieties / products that you have as options to edit to, only include products that you have added in the Product tool. In the best case scenario, you have added the variety in products, then used a setup file or data sync to get that variety to the display, and recorded your planting with it. The varieties you are not seeing as options to edit to, I'd presume those were hand entered on the display at time of planting. The quality of these hand entered varieties typically varies between not great and terrible... so we try to drive consistency to the master list in products.
What if the product you want to keep is the one entered manually in the field?
