Search Forums | Classifieds (108) | Skins | Language
FieldView Intelliview 12
cooter7
Posted 7/13/2026 05:00 (#11699186)
Subject: FieldView Intelliview 12
SW Ontario
Had a cr 7.90 2017 intelliview 4 and iPad running field view, worked fine. Went to a 2025 cr 7.9 with intelliview 12 and everything works except the auto swath is randomly flashing red all across at different sections so it’s not counting acres properly. Which then
Makes the yield read high. Header is reading height. Sometimes the combine pic is jittery on the iPad as it’s tracking. Do I need an adapter for the puck or does it have to do with the gps signal it’s getting from the output.
