Search Forums | Classifieds (97) | Skins | Language
Tile Plow AGPS Exporting Files
gpsdude
Posted 7/9/2026 12:40 (#11696442 - in reply to #11695937)
Subject: RE: Tile Plow AGPS Exporting Files
NE South Dakota Clark, SD
You can export out as shapefile, GPX, NEZ and several other formats directly from the program using the export utility. If you are still running a software version from that era, I would recommend the NEZ export as it is corrected to your control point if you used one. If you did not use control points, then the shapefile con be converted to KML for free online to go to Google Earth. The GPX format will also load into Google Earth as a points file. I personally read the NEZ file into GK Technology Inc Ag Data Mapping solution so I can do any cleanup needed and print maps using whatever background image I prefer. Feel free to reach out if you need a hand. I was an AGPS dealer from 2009-2015. Just a heads up make sure the time and date are correct on the computer before opening the program.
