Search Forums | Classifieds (25) | Skins | Language
Un-RTKing a Starfire 6000
RecreationalTillage
Posted 7/2/2026 16:33 (#11690770)
Subject: Un-RTKing a Starfire 6000
West Central MN
Over the years, was using a Starfire 6000 with RTK radio on the dealers network. Want to use the globe for baling hay today ina tractor with 4600 armrest display and can't get it out of RTK mode to use SF1.
Correction mode "RTK" is grayed out and can't be changed on the Starfire screen.
Found the info below in an older AgTalk post, am in Technician mode, changed the GR6.001 from zero to 1. Next it comes up with TCM calibration, which makes sense, but the next screen says "This Device is Not Responding." What am I missing?
_----------
4600/4640
Main Menu > System > Diagnostic Center > Controllers > Press and hold the controller button for 10 seconds to enter Tech Mode, scroll to ITC.001 for SF3000 or GR6.001 for SF6000> Scroll to Address 180 >tap on this bar, tap on the Zero, this will open a numeric key pad, change the number 0 to 1, then accept, this has cleared the almanac, you can X out now and go to the StarFire page, it may take up to 45 minutes to regain full strength signal, keep powered up until receiver is showing 3D SF1
Edited by RecreationalTillage 7/2/2026 16:39
(Screenshot_20260702_163247_Gallery (full).jpg)
Attachments Screenshot_20260702_163247_Gallery (full).jpg (113KB - 8 downloads)
