Search Forums | Classifieds (33) | Skins | Language
Steady Steer on 51xx or 52xx Maxxums?
schwinnj
Posted 6/30/2026 18:57 (#11689074 - in reply to #11688949)
Subject: RE: Steady Steer on 51xx or 52xx Maxxums?
Northwest Ohio
I do have a couple other questions since you've completed install to basically the same model:
1) How did you route GPS cable to antenna on roof? Thought about going up B-pillar behind right door (where the cigarette lighter is). Removed that trim panel and it looks hollow behind it and would be room for cable, but didn't see access to roof from behind this panel.
2) Electrical supply. Did you use plug to right of seat (on left side of lower console)?
3) Any ideas on wire management ... as it looks like a gob of wire?
Thanks in advance.
