Search Forums | Classifieds (28) | Skins | Language
Should the larger or smaller tank go on front of tender trailer?
JD8345
Posted 6/3/2026 20:07 (#11664848)
Subject: Should the larger or smaller tank go on front of tender trailer?
I’m putting together a spray tender trailer that for this year will have a 3000 gallon flat bottom and 1000 gal flat bottom transport tank on it. Should I put the larger tank over the semi axles on front of trailer and the 1000 gallon tank over the rear tandem axles on trailer or other way around? Thinking I want more weight on tractor side of things
