Search Forums | Classifieds (1) | Skins | Language
Ils manifold leaking 8285r 2013
BIGGREEN78
Posted 6/3/2026 18:13 (#11664773)
Subject: Ils manifold leaking 8285r 2013
I recently have had issues with our 8285r series tractor at first it had been leaking from the oil pressure sensor (blown o ring ) i then noticed a very peculiar leak coming from in between the weight rack and the differential housing it bolts to I’ve checked everything above it and around it it’s literally coming from the seam between t he to so I pull the ILS manifold i resealed everything on the thing there was about 100 orings put it all back together and it’s still seeping out of the one spot and is getting progressively worse it’s been surging aswell (Ils going up and down ) but it’s been doing that for awhile im going to pull it back off as soon as I’m done with planting beans but any info would help
