Search Forums | Classifieds (2) | Skins | Language
Ag leader right path
TS79
Posted 5/20/2026 20:59 (#11652386 - in reply to #11652100)
Subject: RE: Ag leader right path
NE Iowa
what type of tractor are you pulling the planter with? I would agree they have some work to do.
The allowable error of low, medium & high. Low means that the system will react if your implement is offline 1", medium is 2" and high is 3".
I run the maximum vehicle offline for straight at 4-5 inches so it's not overreacting. On bigger side slopes you can always adjust it higher.
On the fields that are pretty flat I would just turn it off as it really wasn't needed.
I don't have anything to compare it too, but you do have to remember is passive implement guidance so it's basically just 'reactive'. It would be nice if they could make it a little more 'proactive', I'm not sure if they are looking at the currently pitch/roll/yaw of the steering controller to estimate of much the implement may move and be ready for implement draft.
