Search Forums | Classifieds (60) | Skins | Language
Surestop clutches sticking "on" not letting me plant
ShopTeacher
Posted 5/6/2026 08:03 (#11638825 - in reply to #11638363)
Subject: RE: Surestop clutches sticking "on" not letting me plant
NW MN
When lubing the meter drive chains, are you making sure to not spray lube directly on the clutch and keep heavy amounts of line from being deposited on the clutches? Lube inside the clutch can cause the wrap spring to slip or not grip firmly.
