Search Forums | Classifieds (60) | Skins | Language
Precision Planting PDM Solenoid
Leene
Posted 5/4/2026 21:43 (#11637616 - in reply to #11636054)
Subject: RE: Precision Planting PDM Solenoid
Franklin NE
You need one that is 100% duty cycle. Like the ones on the older International 66 series cab solenoid, those don’t bolt in the PDM. You can bypass the solenoid but you have to disconnect the tractor harness from the planter when not in use or it will run the battery down.
