Search Forums | Classifieds (60) | Skins | Language
Greenstar rate controller on 1770nt
deeretech14
Posted 5/2/2026 07:03 (#11635110)
Subject: Greenstar rate controller on 1770nt
SW Ohio
I have a 24 row 1770NT that has a ground driven demco piston pump for the 2x2 fertilizer. It has 2 electric ball valves that switch position to stop flow to the rows, but maintain a path for the pump to circulate. I want to set up a greenstar rate controller to run these valves off section control. I can't seem to get it to work correctly. They are 3 wire valves and it is currently working backwards. It flows fertilizer when the foot switch is off and stops when switch is on. What am I doing wrong? Is it something simple in the setup?
