Search Forums | Classifieds (58) | Skins | Language
Converting to Bypass servo for Ag Leader Right Spot
pontithad
Posted 4/6/2026 17:26 (#11609271)
Subject: Converting to Bypass servo for Ag Leader Right Spot
Central MO
I'm going to switch a Spa-Coupe 4455 over to Ag Leader Right Spot and part of the process involves switching from inline servo to bypass servo so I can maintain consistent boom pressure. I looked at another install on a Coupe today and they ran theirs to the top and the tank and just dumped in back in on top. The problem they run into is that they create a lot of foam in the tank that way. My question is if anyone else has done this and where are they returning the excess spray solution to? I'm tempted to plumb back into the pump supply line near the sump of the tank, I'm worried it could create problems in the form of air pockets there. So should I look for another way to return as low as possible in the tank?
Thanks,
Thad
