 Eastern Iowa | Not sure if here, or machinery talk is the correct place to post, but here goes:
2014 JD 7280R with Green Star 6000 and 7" armrest display. Will apparently intermittently flash power during operation, causing guidance boot warning screen to come on as though you just started the tractor, and serial warning tones. No pattern to where or when it will happen, sometimes shortly after startup, or it may operate normally for a couple hours before acting up. But once it starts will generally act up continuously afterward every few minutes. When it happens, guidance operations fail and I drop to 2/4 pie pieces indicated on the display.
Plug pins and cables at the receiver and guidance controller behind the seat are neither corroded or loose. I have attached photos of the main warning indicators the tractor shoots at me when it happens.
Any one have this issue previously or an idea where to look for answers? Deere tech thinks it's a wiring harness problem or possibly a memory capacity issue with the tractor? Just looking for ideas at this point.
Edited by GangGreen 4/3/2026 15:44
(Screenshot_20260403-151859 (full).png)
(PXL_20260403_201918445 (full).jpg)
(PXL_20260403_201931756 (full).jpg)
Attachments ----------------
Screenshot_20260403-151859 (full).png (179KB - 9 downloads)
PXL_20260403_201918445 (full).jpg (156KB - 10 downloads)
PXL_20260403_201931756 (full).jpg (149KB - 9 downloads)
