Search Forums | Classifieds (58) | Skins | Language
Ag Leader Surestop Clutches to older JD Rate Controller
zarcus
Posted 4/3/2026 18:26 (#11606370 - in reply to #11606118)
Subject: RE: Ag Leader Surestop Clutches to older JD Rate Controller
Thank you for the detailed explanation. I do have the clutches with red and black. So if I get a standard 37 pin Ag Express cable that has a 24 pin to each half of the planter. I should be able to reverse the 2 wires going to each clutch and be good to go.
