Search Forums | Classifieds (20) | Skins | Language
JD Ops Boundaries with Pix 4D
   Forums List -> Drone TalkMessage format
sloughclub
Posted 3/27/2026 21:38 (#11599346 - in reply to #11596778)
Subject: RE: JD Ops Boundaries with Pix 4D
Southern Missouri
Aerial mapping can be different from ground based mapping, a tree limb sticking out 15 ft above ground will look like an obstacle and be an obstacle for a drone flight but might make you want to run a tractor away from it when in actuality a tractor pulling a wide tool could simply go straight and let the implement pass under the tree limb , not really big deal but can happen. Aerial mapping is a must to me for aerial applications but a ground based mapping might actually be a little more correct for ground based actions .
