Search Forums | Classifieds (15) | Skins | Language
Agco hvac
notillgleaner
Posted 12/2/2025 07:55 (#11454172 - in reply to #11452699)
Subject: RE: Agco hvac
Central Kansas
drk - 11/30/2025 20:21 Have a RT120A, 2006 model, having an issue with the cab blower fan. When you first start it it will blow air out of all the overhead vents, after awhile only the left-hand vents will have air coming out? I have replaced the blower fan a couple years ago and as I recall it had 2 fans setup to run off one motor. Is there a blend door or something else sticking shut not allowing airflow? Or is it possible only 1 fan is turning? Also is there anyway to make the defrost run longer before it kicks back out? Thanks.
I was hoping to see some responses to this thresd.  I've got a Challenger that acts similar..
